I'm sorry, 1995 Bobcat 853What brand and model machine?
The 853 is one I don't have a service manual for, so I edited the subject line of the post so that maybe someone with that manual will answer.I'm sorry, 1995 Bobcat 853
I have about 60 psi at full throttle. Can the hydra motors be damaged by pulling the bobcat around with or without the hoses being connected. I have no movement when the sticks are moved. The only thing I havent gone thru yet are the motors.The 853 is one I don't have a service manual for, so I edited the subject line of the post so that maybe someone with that manual will answer.
Most machine around that size run 175- 200 psi.
There are about three different pumps that were used, could you specify your serial number?I have about 60 psi at full throttle. Can the hydra motors be damaged by pulling the bobcat around with or without the hoses being connected. I have no movement when the sticks are moved. The only thing I havent gone thru yet are the motors.
You can pull the machine very slowly and not hurt anything. If the hoses are off the motors you'll want make sure no dirt gets in them.There are about three different pumps that were used, could you specify your serial number?
Thanks for all the replies, serial #5128-16479.You can pull the machine very slowly and not hurt anything. If the hoses are off the motors you'll want make sure no dirt gets in them.
With your serial number break, your charge relief setting is set at 230 psi. So for the most part your charge pressure should not be too much lower than that for your pump to work decent.Thanks for all the replies, serial #5128-16479.
