Plenty hard but it doesn't need much as the pedal moves normally through full travel. I have several machines so I know what should happenHow hard are you pushing the pedal down? if you push too far, you engage the dentent mode. With that said, it shoudl easily push the wheels up, it takes a good push to engage detent mode.
What happens when you try to lift a load?Plenty hard but it doesn't need much as the pedal moves normally through full travel. I have several machines so I know what should happen
This machine is down with a bad alternator. I will put it under load when fixedWhat happens when you try to lift a load?
