753 Won't start
bradley5010
I used my 753 to load hay yesterday and it ran fine. Loaded it up yesterday afternoon and hauled it home. Went to start it and can't get it to start. Left it for the evening and atarted messing with it today. I was getting some smoke like it was getting some fuel but not hitting off enough to start. Started tracking things down and am having trouble getting a good supply of fuel to the injection pump. I even wired in an electric lift punp but can't get a consistant flow of fuel from tank. Thoughts?
Fuel cap vent pluged first but most likely the pick up line in the tank is off or cracked check the fuel filter too
I'm having a similar issue with my 753. It wouldn't crank at all, and after some digging, found that the starter relay was bad. Swapped out with the glow plug relay and it ran, but next time I went to start it, it only coughed and sputtered. It actually fires up for a second, coughs and blows white smoke and dies. I get an E-6.2 error, which I think is engine speed sensor. Last time, I was able to restart after several attempts, and it smoothed out and ran just fine for an hour. I haven't run it again. I was going to change the fuel filter first. Still a good idea? I need to stock up on those...
i'm guessing fuel pickup tube broke off in the tank.
