All, I know this subject has been hashed over several times, but I have reason to believe my 743B is leaking hydraulic fluid into the chain case. (I opened the plug at the front of the chain case to find clean oil (probably hydraulic fluid) gushing out. I used a siphon hose to remove some more fluid and found what looked like water and then some dirty oil started flowing out). So, I removed the drive motors and as per the service manual, removed the removable seal carriers (one on each side). My questions is this, are the seals mounted in this removable seal carrier the ones that need to be replaced to cure the problem (there appear to be two seals in each of these seal carriers). The manual also indicates to replace a large o-ring that fits between this removable seal carrier and the motor carrier ... hopefully these parts come as a kit (2 seals and o-ring). As for how water got into the chain case, anyone have a clue ? I will say that I had to take the engine out to get to a hydraulic leak that I thought was coming from the oil cooler, turns out it was just a hose that connects to the cooler. Anyway, I power washed the engine bay while the engine was out and I could have forced some water in through the chain case breather, other than that I don't know.
