Fabricator
Ok, I think that I finally have this problem licked. I had to let it sit for awhile to get some other things done and can't believe that it has been over a month since I was last working on this. August just disappeared!Ok, rather than pull everything back apart again, I was able to reach under the carb and remove the access plug for the main jet. No fuel came out. The plug sits at the bottom of the bowl, so I was expecting at least something...
So it looks like ordering a new fuel pump Monday morning is the next step in this story.
Anyway... I was about to the point of selling it, taking it to the dealer, or just burning it to the ground - depending on the day and my mood. Finally had some time yesterday to really spend some time with it.
It obviously wasn't getting fuel, so I wanted to be systematic about things. Took the fuel line off after the filter and got good fuel through the filter. Took the line off the fuel pump and turned the key - fuel solenoid opened and I got good fuel. Took the line off after the fuel pump and got good solid squirts from the pump. Again took the access plug off the carb for the main jet - fuel bowl was empty...
Took everything off to remove the carb thinking the float was jammed. Shook the carb before I took it all apart and could hear the float shaking back and forth inside. Ok...?
Took the bowl off and sure enough, the float moved freely. But then noticed that although the float was moving, the needle was staying put... Got my pocketknife blade in and pulled the needle down to free it. Pushed on the float and the needle moved back up - but fell back down when the float was released. Did this several times to make sure it was moving freely.
Put everything back together and after some cranking, got it to fire up for the first time in over a month. Wrapped everything up before dark last night. Have to go out today to see how she runs.
But isn't it always the littlest of things that really stump you? I guess the new rubber grommet that the needle passes through had just enough friction to not let the needle slide freely. Maybe a drop of gas or oil on it during assembly would have solved all my nightmares and hair pulling.
But the good news is that with a rebuilt carb, new fuel solenoid, new fuel pump, and cleaning a couple decades of crap out of everything it ran last night better than it ever has.
