Fabricator
Just went through and changed engine oil and filter and the hydraulic oil, filter, bronze filter, and a hose that was leaking. Working on all of that, I also noticed that the PO had screwed up the fuel shutoff solenoid and taped things back together. So I replaced that as well since I was in there. First time I fired it up things seemed to run well and I went through the motions of driving forwards and back and running the bucket and arms to bleed out any air. Probably ran for ten to twenty minutes. Then it died. Sort of struggled for a bit and was running rough before it just cut off. Since then, I can get it started with some effort and it will run for a minute or two before going into this "struggle" and dying. Seems to be getting fuel and spark, but I haven't torn everything apart. I did pull the solenoid thinking I may have dislodged some crud in the R&R but the filter on the input side is clean. Any suggestions?
