2000 863 bobcat ?
blindman
i just bought a 2000 863 used bob cat, got it home and found the aux hyd flow switch doesn,t work correctly.the right joy stick(sitting in the seat) has a switch that moves left to right like a toggle switch that is supposed to change the flow direction of the aux hyd. more often than not i doesn,t work , it always works to the left but hardly ever works if you move it to the right.any help would be appreciated. tks blindman
Hopefully it is just dirty contacts on the thumb switch. If you can get it open, try spraying a little contact cleaner on it.
Good luck
