I usually have the opposite problem with anything mechanical. So I started it up and it ran fine. Went to turn the key to shut her down and nothing happened. Kept on running. I pulled the ignition switch and everything was hooked up. Someone before me really did a job on the wiring behind the gauges. The gauges have never worked since I owned it. I ended up just stalling it to get it to shut down. I did not want to run it out of fuel as I have made that mistake before. Any suggestions. Is there a fuel pump solenoid that is not shutting down? I'm clueless. Thanks
