Wisconsin 4 cylinder vh4d head bolts?
m37guy
Anyone know if i need special head bolts or can i use grade 8 ones from the hardware store? Also whats the torque and tightening order for them? Thanks in advance!
I use grade 8s. Torque order is basically top to bottom from inside to outside. Someone will give you the torque shortly .... if not I will get it to you when I get home tomorrow.
According to Google, head bolt torque is 22-24 ft.lbs. Check page 19 on link. http://www.wincogen.com/files/downloads/winco_engine_maintenance/wisc_vh4d_repair_manual.pdf
Thanks guys I'll be saving the PDF!
