dakotadigger
- Joined
- Oct 31, 2010
- Messages
- 18
So I am in process of an engine upgrade. I have searched a few different forums and have not seen much on swapping a v2203 in place of the v1902. Long story short my 1902 gave out on me and I happened across a low hours 2203 out of a carrier reefer unit so I figured what's to loose. I am at the point now where my old engine is out and I have the oil pan swapped over I also added on my stock fuel filter since the 2203 was lacking one. I am now working on the bell housing and from what I see is the only dimensional differance in these two motors. Yes the glow plugs andr injectors are positioned different but I think you know what I am saying. Anyhow The 2203 has a slightly larger flange that retains the oil seal. This I was preparred for as it was the only information I could find on the other forums about any differences. However the bolt pattern for the bell housing is also bigger. Now I do not have a milling machine but a burr bit will have to do I need to open up the center of the bell housing to fit the larger seal and I will need to slot the holes to accomidate the larger bolt pattern. Luckily the far two top And two bottom holes line up and do not need to be slotted so this will keep every thing lined up and tru Does that make sense. I will post some pics to show in detail the modifications but for now I have to take a break from my project for camping and the holiday weekend Regards
