Is it anyway I can check the controller besides taking to dealer? ACS T250 I've been fighting a actuator code, I've swapped actuators from one to other, code would follow showing me bad actuator. It was too late to order so I decided to open bad actuator up. Anyway mounted it up and had back off and got it showing neutral and no codes. Cranked and worked everything, worked good. Put everything back together and it shows 32-34 again. I figured I was just lucky. My problem now is I went and double checking again and now it want code anything but the 32-34 code. If I have both actuators unplugged it just codes 32-34. It should throw 32-39 first, suppose to check lift actuator and handle before tilt. Doesn't matter if both or 1 or either way the harness is hooked up just throws 32-34. Makes me think controller. I've unhooked battery, checked all my spools and everything that I've found on sites to check. Anybody got any ideas I'd really appreciate. Thanks
