T190
skooter
Can anyone tell me the location of the spool lock solenoid and can it have anything to do with machine not starting? Im getting a code of 18( spool lock solenoid) and 06 ( short to ground)
It should be located on the side of the control block, i can't give you an exact location though, i have never worked on one. But thats where it is on all the other modern machines. Depending on what it calls the spool lock solenoid could be the locks that prevent the lift and tilt spools from moving, these are located on the control block rite where the spools enter the control block. They are only small.
