long post
been fighting with this machine for a year (05 t250 sjc) have had both final drives rebuilt and the main pump gone through and have been told is good.
original issue, right drive quit out of no where. All other functions worked as they should. fast forward the lift/tilt quit working later on but left track still drove.
had both final drives rebuilt and pump sent out for inspection. got it back and left side still works fine as it always had. Right track does move now but mostly at higher rpm. right track will go forward even when you motion joystick in reverse position.
it will also move slightly ahead without touching joysticks when it is revved up. lift/ tilt seems to move sometimes also at higher rpm but mostly seems to be locked out, as it will bog down when moving joysticks for lift tilt. does have a code for low charge pressure and code 38-15 for right wheel speed fault
