2016 T770 P Brake/Lift/Tilt issues
markpps
I have an odd issue. A couple weeks ago the lift lock solenoid when out and I replaced it. The next day the left drive motor began squealing terribly and shortly after the lift tilt quit working and would only work when the parking brake switch was on. I removed the drive motor and had it professionally rebuilt and installed it. Today while testing everything was fine then after about ten minutes the lift tilt quit working and would again only operate when the parking brake switch was on. You can still drive it when the parking brake switch is on and I'm guessing this is why the drive motor went out but not 100% on that.
I note that the lift/tilt takes two presses to begin operating when turning on the parking brake. I also note that the unit has a slight delay before it will move the first time with the parking brake on.
I'm at a loss. I have been looking at both the hydraulic and electrical schematics and can't seem to come up with a direction to go next. Nothing makes sense. The last thing I want to do right now is take it to Bobcat...
The three BICS lights all operate as they should. They are off when the press to operate button is pushed.
Any thoughts are appreciated. I won't get back on this until monday.
