S250 fuel starved ?
cbnc
City & State/Province
SE North Carolina
On my 09 S250 clogged up my air filter in the dust to the point I could barely move the machine. Didn't see the thick black smoke im used to with clogged filters but more white/blue.
New air filters and it ran rough at idle for 10 minutes. Kept pushing up the RPMs until it would run smooth without smoke. Now consistently when im pushing 2400 RPMs it will start climbing back down and back comes the white/blue smoke. Drop it back to 1900 RPM and it will run all day with no issue. Push back up to 2400+ and after 15/20 seconds it starts bogging back down and smoking.All this with no load.
NO CODES ON THE DISPLAY
Coincidence that the dirty air filters choked it to a crawl and have a fuel issue at the same time ? Oil looks good and at correct level. Was thinking my turbo was pushing oil into the exhaust but its not really losing oil.
Any suggestions ?
well blue means oil, so it's burning it somewhere. I'm thinking there's oil pulled up while the air filter was clogged and the turbo pulled oil, so I'd check that first. Have you checked the lower intercooler pipe to see if there's anything wet?
