S250 aux hydraulics only working one direction
rmaffet
I've swapped the stems and the solenoids and the problem persists in the same direction. Our broom works in reverse (pushes). Anyone w any ideas one where i go from here? we work on lots of trucks but no skid steers. we are not afraid of tearing things down, but for simplicity sakes, like to go after the problem instead of chasing our tails.
Have you tried to reverse the continuous flow?
If you have joystick controls:
To reverse flow hold the auxiliary switch to the left, press VARIABLE FLOW or MAXIMUM FLOW ONLY, and then press the front switch (trigger). This will pressurize the male coupler.
