Alright. Thank you. I agree with you. Most people use a machine to flush systems. This setup works wonders but lacking volume on this application. Solvent and air at 160psi pounded through multiple times until the system is clean. I've done about 5 flush bombs thus far.metal is still coming. In theory though the oil from the cooler goes directly to the hyd filter?.. So if you got 99% out the last bit will be filtered before its returned. Every other line has beens back flushed. What does a guy do about the Rams? As for the motors they will be great to wear or marking on them pieces. Thanks again Dan
