No start
wes6366
Having some issues with a bobcat that was given to me by my grand. Father before he passed. When I first got it it had been sitting for a few years so changed all the fluid everything ran fine after sitting a month or so it ran fine but started shutting down on high oil pressure code so I got a new sending unit no change. Bought a manual gauge to see what pressure is but now all I can get it to do is click when I turn the key. Any suggestions
What model Bobcat do you have?
What model and do you have Serial #? Right now it would be a guessing game.
I would start with testing battery to make sure its good, and then check starter relay, and electrical connections from battery to fuse box/starter
for the now clicking sounds!
as for other issue, what exact code is is throwing?
and when you said you replaced all fluids, did you drain old fuel?
drain hydraulic fluid?
and are you sure the hydraulic fluid is at correct level, (no air bubbles in system?
and a fresh filter was installed when you replaced it!?
S150 when I go to the shop I will get you the other info. Yes I checked battery I thought damn they gave me a dude battery but it was fine. When I replaced all the fluids motor hydro gas and all the filters. Since the day I picked it up it would not keep a prime on the fuel so I put a new lift pump still wouldn’t keep prime so put a secondary pump on it once I did that it ran fine then later started blowing the high oil pressure code and then after replacing the battery with a new one and putting a manual oil gauge o. It all it does is click can’t remember what the code was I will have to check it for that Again
the clicking might again be your starter relay! that's what they sound like when not working properly
