RC100 lost power to one track
RC100
I was operating my ASV RC100 today and when I went from low to high speed I lost power to one of the tracks. The right track works fine although the left one only moves a small amount when I attempt to move. Any ideas?
I apologize that I didn't reply sooner but I haven't been on here in awhile. First check your wiring. I cannot remember if the RC100 had fly by wire controls or not.
THen you get to check you brakes. ASV uses a hydraulic cylinder that pushes a rod into your plantary sprocket to stop it. If that is engaged you need to figure out why its not dis-engaging.
Next guess is your plantetary failed. This happened to my ASV 4810. I listed how I got mine off in another thread under ASV so look for it and that will give you the rough on how to get it out and what to replace. If your lucky its just a few bearing. If your not its a whole new planetary.
Good Luck and keep asking questions. this forum has been very helpful too me.
Dozer
Dozer
Lost power to passenger side track on my 98 4520. Check pressure at drive motor and had almost 4000 psi, thought motor was bad, but while removing it notice planetary was separating. Had a local mechanic look at it, and he thought we could rebuild it with a parts breakdown of what to get. It is an Auburn 21. 74:1. Can anyone help? Thanks.
Have you tried the dealer for a parts break down?
