bobbie-g
- Joined
- Mar 15, 2004
- Messages
- 577
OK, sports fans, here's an easy problem to solve: 773 with the V2203 Kubota engine, 1100 hrs, original owner, never abused or neglected. Died abruptly under load. After troubleshooting, found the pickup tube in the fuel tank had fallen off. No surprise there. New pickup tube from Bobcat installed (including new strainer/check-valve, and the teensy clips for the pickup tube), also new hoses from the pickup elbow all the way up to the high pressure injector pump, new primer bulb, new fuel filter (tried two now), and new lift pump (actually tried two new pumps). Swapped the primer bulb from the new to the old and back again, no change. The "primer valve" at the input to the injector pump is turned off (open to prime the system, closed to run). And we've reversed the inlet and outlet lines on the lift pump, just in case we had those backwards (we didn't). Here's the rub: runs fine under light load for half an hour, but stalls under load. Once it stalls, walking behind and pumping the primer bulb will keep it running enough to get it into the shop. Disconnecting the fuel line at the input to the injector pump only gives a dribble of fuel when cranking the engine, so that's not what it should be. But, connecting a Holley electric fuel pump in place of the primer bulb lets the machine run under load at full throttle. So this is a simple fuel supply issue. But what gives here??? This is a really simple problem, isn't it? What am I missing? Why haven't the prev steps solved the problem? I think it's extremely unlikely the lobe driving the fuel pump partially broke off, but I sure can't come up with anything else that would be the cause. I think the last test will be to cut the line going into the injector pump and install the Holley pump there. That will let the Holley suck fuel from the tank all the way through all the components. Opinions?
---Bobbie-G
