did you bleed the air out?Replaced the pickup line and screen but it seems to lose its prime and won't stay running. Anyone else have this issue?
Yes, I bled the fuel filter and the pump. I’m wondering if it’s the lift pump.did you bleed the air out?
you need to bleed thro to the injectors, many times I crack the line on the injectorsYes, I bled the fuel filter and the pump. I'm wondering if it's the lift pump.
check your fuel lines for a vacuum leak, that will cause it to lose prime , was there a check valve in the system that might have gotten removed?you need to bleed thro to the injectors, many times I crack the line on the injectors
Someone the other day had a Kubota that they left the bleed screw open on the pump and had similar issues, if you replaced the fuel filter of course you double checked the gasket was intact on the old filter.Replaced the pickup line and screen but it seems to lose its prime and won't stay running. Anyone else have this issue?
There wasn’t a check valve on the old line but the kit I bought had one. I believe the old one is on the bottom of the tank.check your fuel lines for a vacuum leak, that will cause it to lose prime , was there a check valve in the system that might have gotten removed?
I checked the old gasket and it was there.Someone the other day had a Kubota that they left the bleed screw open on the pump and had similar issues, if you replaced the fuel filter of course you double checked the gasket was intact on the old filter.
I never had a problem myself but did have a young mechanic come and ask me once when he serviced a Kubota engine when I walked up to the unit I noticed that the gasket was missing on the old fuel filter I asked him about it he found it on the engine, it would start then die reprime and start an die.
I’m going to replace the fuel line from the tank to the squeeze bulb.check your fuel lines for a vacuum leak, that will cause it to lose prime , was there a check valve in the system that might have gotten removed?
I’m going to replace the fuel line from the tank to the primer bulbcheck your fuel lines for a vacuum leak, that will cause it to lose prime , was there a check valve in the system that might have gotten removed?
There wasn't a check valve on the old line but the kit I bought had one. I believe the old one is on the bottom of the tank.
make sure to check that primer ball for cracks too. and those primer balls have a check valve inside of them too.There wasn't a check valve on the old line but the kit I bought had one. I believe the old one is on the bottom of the tank.
I'm going to replace the fuel line from the tank to the primer bulb
