Where is the best place to obtain plugs for hydraulic lines and what assortment of sizes would be best for a Bobcat 642b. I need to replace a hose and I don't think I can make the shop vac trick work long enough to have the new hoses made!!!
I'm cheap! I use old hose ends and MIG weld the hole up, presto! cheap plugs. I'm slowly increasing my collection, but as always, you never have enough of the rite size!!!!The place where you have the hoses made will have either steel or plastic and they should be reasonable. On the 632 for instance the line from the filter to the port block takes a #10 plug, the big ones on the pumps are #12.
Tazza, Did you see me email?I'm cheap! I use old hose ends and MIG weld the hole up, presto! cheap plugs. I'm slowly increasing my collection, but as always, you never have enough of the rite size!!!!
Hydraulic shops will have plastic screw on plugs, they really are only good to keep dirt out, not to keep oil in, they will still drip oil. For a good seal you need the steel ones, again a hose shop will have these but expect to pay for them!. The steel ones will not leak and if you need to run the machine they will hold the pressure back too.
If you don't mind loosing a little bit of oil plastic will do the trick. I think when i last got them, i paid 50c each.
Sure didTazza, Did you see me email?
