G Goblish Member Joined Dec 19, 2010 Messages 17 Apr 10, 2011 #2 Question on a 2001 773 Bobcat. Where the oil filter is on the engine, there is a rubber plug below that. If the plug is removed what kind of fluid is suppose to come out of that. It's not oil that came out, is it antifreeze? Thank you.
F Fishfiles Well-known member Joined Feb 8, 2007 Messages 1,698 Apr 10, 2011 #3 that round thing between the block and the oil cooler is a engine oil cooler , engine coolant runs thru it
OP OP G Goblish Member Joined Dec 19, 2010 Messages 17 Apr 12, 2011 #4 Fishfiles said: that round thing between the block and the oil cooler is a engine oil cooler , engine coolant runs thru it Click to expand... Thanks for the information, I drained it all and filled with new figured it was getting time.
