air filter code on s150
gwilkrrs
s150 error code is for air filter restriction. i have replace the air filters and cleaned the canister but the code persists. any ideas?
i unplugged the sensor on the air filter housing- is there a way to blow this out and re set it or does it need to be replaced?
oi took the filters out- replaced them even tho they looked good- cleaned the housing-
started the machine and instantly get the beep and code for restriction. can i clean the sensor, or does it need replaced?
I would try to clean the sensor before replacing it. You could try to blow it out but if something is jammed in it, it will probably need to be removed and then cleaned out.
There could also be something plugging the elbow that the sensor is screwed into.
