guycarrier
- Joined
- Feb 11, 2009
- Messages
- 1
Recent purchase. Two issues. 1- Right hand drive train is tired. Full forward RH stick causes Red Light and hardly moves the wheels. Full reverse stick - same problem. Correct terminology escapes me but, the lower pressure taken on the tee above the pumps hovers at better that 200 psi. At full throttle the RH side does move but with no real Umfp! FYI. Completely new oil, new filters (2 of them), fully cleaned strainer. I am trying to decide is it the pump or the motor or the pressure relief valve that is tired. Any ideas welcome. thanks, 2- The Bucket really only wants to curl up or down if and only if there is some movement on the ARMS peddle. If I try and move the peddle for the bucket there is a very slight movement and then is stalls. If I add some ARM peddle, the bucket wll curl up or down depending on the peddle decision of either up or down. Any ideas welcome. thanks,
