Atilathehun99
- Joined
- Dec 17, 2011
- Messages
- 123
I've just upgraded from late 70's technology (722) to early 90's (743B). I'm getting to know the 743B and have now and later will have more questions that I know the members of this forum will be glad to weigh in on.
Today it was about 30 F and I let the glow plugs go for first a full minute. It then took a couple more 10-15 second heat/start attempts before it did start. That was not un-expected. I let the unit warm at low-mid throttle for about 10 minutes before operating.
My primary question is this - how long should I let the unit warm up before using it? I know the answer is temperature dependent but I'm interested in hearing the opinions and experiences of y'all.
Regarding the glow plugs and starting this is my first diesel anything. I've operated a lot of diesel powered construction equipment but almost all has been Spring through Fall and not Winter. This unit has a block heater as my 722 did which I intend on using it when temps get lower. It's installed but I haven't plugged it in some I'm assuming it works. A secondary question is - how long should the block heater run before starting? I know that too is temp dependent but as above opinions/experiences welcomed.
Thanks in advance for all replies.
