Mustang/vickers parts please help
Boxhead
Hi all, I am in desperate need of some parts for the vickers pump in my mustang 552. I need 2 rotating groups for the TA-19 vickers pump that is installed in the skid steer.the groups that are in mine are pitted which is causing my issues with the drives, I am being told over here (Australia) that they no longer supply parts for this pump. I am in desperate need of these, can anybody please help to locate these parts from anywhere? I would be very appreciative if somebody could help. Cheers Corey
Rookie
Did you try here? http://www.phphyds.com/Vickers-Piston-Pump-Parts/Vickers-TA19-TA1919-Spare-Parts.html
Corey - i too am from .au, i have bought a few sets of rotating groups, never had an issue. Parts are all still available, and at a reasonble price too. If you replace the rotating groups, you should replace the brass wear/valve plates too. They get worn and will give you lower power. If your old ones aren't bad, you can use a sheet of glass and sand paper.
look up my profile, send me an email
B
Boxhead
Thanks for all your help tazza, ordering parts this week. They linished the plates and have one side at 91% the other at 82%. Will install them in a couple of months. Cheers Corey
Good to hear its all being done.
Why did they only get them to that percentage? I got mine flat with sandpaper and glass, well they seemed to be perfect :) I'm sure they are better than they used to be at least.
