It is a ujoint coupler that connects the engine to the transmission. You can see it when you remove the seat. I believe NH just calls it a coupler, but it has a ujoint in it. When engine is running, I can see "slop" in it, just like an automotive ujoint. I already bought a new joint from the dealer.I've had three NH's over the years and none has had a u-joint. What are you talking about and how do you know it's bad?
I know what you are talking about and the easiest way to replace it is by removing the pump assemblies. [email protected]It is a ujoint coupler that connects the engine to the transmission. You can see it when you remove the seat. I believe NH just calls it a coupler, but it has a ujoint in it. When engine is running, I can see "slop" in it, just like an automotive ujoint. I already bought a new joint from the dealer.
Sure looks like a u-joint. Here's a parts page from Messicks.. #13.I know what you are talking about and the easiest way to replace it is by removing the pump assemblies. [email protected]
