Keypad issue
eastsideny
I just replaced the keyless panel on my 2007 bobcat t190 but now it won't start. You press the yellow button it powers up enter password everything works as normal it say press run to start but nothing happens when pressed plug the old one in and it starts fine. Does the new one have to be programmed to the machine or something
Where did you get the replacement panel(new or used)? If it was from a dealer they should have said if it needed programmed or not.
I have the exact same issue. I only replaced the membrane. Everything works when putting in test mode and testing the buttons. The comm test passes. But when I enter my password and it says press start nothing happens. Did you find a solution to your issue?
