How to check hydraulic charge pressure low error code problem
Johnboy
Where do I check to see if this is just a loose connector or sending unit or what else it could be?
Depending on the machine, the sender should be screwed into filter housing, older machines was mounted to the hydrostatic pump.
If in doubt, remove it and install a manual gauge to see what the pressure is. Senders do go bad quite often.
