J Johnboy Well-known member Joined Dec 4, 2013 Messages 94 Mar 17, 2016 #2 Where do I check to see if this is just a loose connector or sending unit or what else it could be?
T Tazza Moderator Staff member Joined Dec 7, 2004 Messages 16,865 Mar 20, 2016 #3 Depending on the machine, the sender should be screwed into filter housing, older machines was mounted to the hydrostatic pump. If in doubt, remove it and install a manual gauge to see what the pressure is. Senders do go bad quite often.
