Help with 763 whinning while turning
Mike763
I took my 763 in to bobcat to have the neutral and linkage adjusted. I also had a flow test done, they said everything was good. Now my machine seems to really wine When I turn. when I push the right hand control it sounds like a valve is open and its leaking. The machine still seems to work Ok, But it doesn't sound good. thanks Mike
When you drive it full speed forward or reverse does it go in a straight line? (assuming your tires are equal size and pressure)
When you le go of the steering levers it stop, does not creep forward ,backward or spin slowly in a circle?
Because those are about the only things the neutral adjustment can affect.
Did they flow test the hydraulic pump, left and right hydrostatic pumps or all 3?
The only thing I can think is if they did not conect a line back up correctly after testing the pumps, but that would be resonable unlikely.
If they did a flow and pressure test could it be air stuck in the system? How long have you run the machine for since it was *fixed*? Air can take a little while to go, but not too long.
I checked My receipt, there was no information about the flow test. The mechanic told me everything passed the test. My receipt said I was suppose to get a print out of the results, which I didn't. I will call bobcat on monday and find out if they tested everything. I Have put about 20 hrs on the machine since it was fixed. Thanks Mike
