Does anyone know what number the axle seals are on a 743? the ones i removed have no numbers on them, the bearings do at least.
I hope to not replace the wear rings, i hope to just linish the old ones (they have no wear marks on them).
Goodtech, the oil seal installation tool, are you able to get any measurements of one at all? i know you can buy them off clark but i bet they want a fortune for it. They look simple to make but i need dimensions if i can get them, if not i will have to just fudge it. As for tightening the bolts, the manual says like 450 ft lbs how on earth do you get them that tight? my torque wrench doesn't get anywhere near that. And you can't fit a socket on the bolt, never mind a wrench on to the end on the socket! I am leaning to the idea of just putting locktight on the threads and do them up around as tight as they were when i removed them.
