Bonez
OK, Ive read that points should be in the fully open position ( assuming TDC ) so if that is correct then I am good to go.... I hope.
.016" is @ the peak of the POINTS CAM lobe. That should be at or near TDC if I'm reading correctly(?) The gap will remain the same regardless of the timing once set. 20* is when they are just breaking (spark) Did you find the plate to be adjustable?So I dove into italthough I was hesitant to do so. Pulled the radiator and muscled the front cover as much as I could, found the timing marks and lined everything up... the first go the points were completely closed so it was 180 out, cranked it around and the gap was too tight so I adjusted it to .016. The spark plugs were also gapped too far so I adjusted them to .025
Now I need to get a battery so I can test the fuel pump and see if it will fire up... I cleaned up the cooling fins on the heads, the radiator is pretty rusted up in the fin area but not leaking, going to treat it to prevent further rusting for the time being.
Now that Im thinking about it.... was I supposed to set the points at .016 on the 20 degree mark or TDC.... as I adjusted it at TDC... hope I didnt goof it... otherwise I know what Im doing tomorrow.
Thanks, After I came in and settled down my mind got racing, and Im like, was I supposed to set the points at the 20* mark or TDC??? Then I re-read the files and the best I got was TDC.... so I was hoping I didnt have to tear this thing back apart as it was a PITA to get to some nuts and bolts besides no room to move the cover. Im afraid to remove some brackets as there is no access to the back side for the nuts and I have seen some YT videos where the nuts fall into the drive chain area and needs fished out... same with the cage bolts, I want to remove the cafe for easier access to work on the stuff but I dont want to get into where I dont need to yet..016" is @ the peak of the POINTS CAM lobe. That should be at or near TDC if I'm reading correctly(?) The gap will remain the same regardless of the timing once set. 20* is when they are just breaking (spark) Did you find the plate to be adjustable?
Just an aside: I've noticed Onan did go to an electronic ignition system for their 2 cyl. engines. Have no idea if it could be retrofitted to their earlier engines but might be worth investigating? If it would work and you could find something in a boneyard; might be worth doing. Otherwise aftermarket would surely be cheaper. Just food for thought.
Didn't see your last post. Yes I think you are good.
Agreed, besides the key switch was bypassed with a toggle, I bought a new key switch so its secured from unwanted tampering. The ignition switch would stick and the others were corroded pretty bad. As I tried to remove the switches the terminals were breaking off so I just decided to replace them all with new and clean up that rats nest of wires since there are some moving controls behind there that can rub the wires so I will put it in a loom as well for added protection.Tearing the console off to redo those rotted terminals properly instead of just re-taping them is the right call and the weatherproof switches are a nice touch.
