I elevated my skid on a stack of planks recently to replace a missing belly pan bolt. while I had the pans down and was cleaning up things I found the two front pump mount bolts were about ready to fall out. this is on a 2005 machine with under 300 hours. so a heads up if you get a chance to drop your pans and clean out check your mounts. I also spent a few hours straightening the pans out and going over everything I could see or feel. I must say that the gehl cab when raised gives good access to most things a lot better than other brands I have worked on. (bobcat) good forum and glad to learn and share. Bill B.
