FiL jacked it up - fuel? help me fix it.
carl johansson
OK guys my father In Law fancies himself as a big time long time operator. In fact, 35 years of shuffling papers and telling other guys what to do. Now he comes up here when I'm gone - to do work on my property, using my 763!
Anyway, according to him, just as he was reaching to turn it off, the thing quit - but it showed 1/4 tank of fuel. guage is always a bit wonky, so most likely he ran out of fuel, but according to him he immediately shut it off, put in 5 gallons - “filled the fuel filter” pumped the bulb (somewhere along the line he broke that thumb screw off - he has not bothered to tell me that yet!
anyway, he cranked it a bunch and could not get it refired. So of course, it's now my problem, since I am now done fixing the lawn tractor he broke yesterday.
When i pump the bulb, fuel is coming out dfrom around the plastic valve at the bottom of the filter. I tried upening it up, draining a bit of fuel, and repumping it, but as soon as I pump the bulb, it starts leaking again. So i assume I need a new fuel filter, and might as well do the oil filters as well while I'm at it, but anyone have any insite or experience for me? i'm just a dumb biologist, The 763 is my first mantoy!
It sounds like he broke the drain valve on the bottom of the fuel filter. Or cracked it. I would have him work on your wife's car. Good idea to change the hydraulic oil filters if you do not know when they were last changed. The filters are not cheap, but I would get Bobcat brand. Also the vent/cap for the hydraulic oil should be changed also if it looks dirty. Every other notch is white vent material. Hard to tell that when its dirty.
