I replaced the wiper with a slightly longer one, but would like it to cover more of the window for visibility. I've been thinking of replacing or extending the arm, Has anone replaced the standard wiper arm on their machine with a longer one?
They don't seem like they are extendable, and with me being 6'4 I'm usually looking right through the muddy part. thanksOn my 93 753 bobcat the wiper arm was adjustable for lenght. Maybe yours is too.
It wiped so low on the window I was looking through the un wiped area. It was a plesant surprize when I noticed that.
I'm not 6' 4" but still have the same problem. A real pain when lowing snow. I have to bend down to see out. The dealer didn't know of a fix, but it sure seems likely that something could be done. I'm going out right now to check for an adjustment on my 236BThey don't seem like they are extendable, and with me being 6'4 I'm usually looking right through the muddy part. thanks
Nope, no adjustment on mine eitherI'm not 6' 4" but still have the same problem. A real pain when lowing snow. I have to bend down to see out. The dealer didn't know of a fix, but it sure seems likely that something could be done. I'm going out right now to check for an adjustment on my 236B
This has been driving myself crazy as well. There has gotta be a fix for this, my neck can't take much more bending to see out the window!Nope, no adjustment on mine either
My old 753 is long gone. Wish I knew if that arm was factory (Had a factory cab) or what brand it was. It was so simple, lift a clip and the solid part just slid out of the tin part that houses the spring. Some one has to make one. or find a longer arm.This has been driving myself crazy as well. There has gotta be a fix for this, my neck can't take much more bending to see out the window!
If you take the motor and gear box apart, you can adjust the throw of the arm another 20 degrees, but you will need a one piece window like I use that is smooth and round, not like the 3 piece one that Cat supplies.My old 753 is long gone. Wish I knew if that arm was factory (Had a factory cab) or what brand it was. It was so simple, lift a clip and the solid part just slid out of the tin part that houses the spring. Some one has to make one. or find a longer arm.
