Emissions
doger5
I have a 1988 743 bobcat and consider tier 0 , having to deal with my local government emissions can I possibility retrofit my engine exhaust to tier 1 or better tier 2 .
where are you from? they can't make you change engines in an old machine
http://www.metrovancouver.org/services/Permits-regulations-enforcement/non-road-diesel/faqs/Pages/default.aspx In metro Vancouver they can , you cannot operate a tier 0 1998 or older diesel engine
An exhaust purifier is the first option I'd look at. It replaces the muffler and is generally consider good enough to make a diesel clean enough to run inside, very close to LP emissions. For starters look at was.catalyticexhaust.com. Never dealt with them persay, but somewhere I picked up one of their frig magnics and stuck it on my tool box.
This engine is classified as a Tier 0 and is required to be registered to operate in Metro Vancouver. Tier 0 engines will be prohibited from operating in Metro Vancouver unless 90 days of registration have been purchased and started on or before December 31, 2014
You can see my problem , I need to get this motor to tier two
https://apps.metrovancouver.org/NRDE/tools/feeestimator.aspx
Use the link above and calculate your engine in Metro Vancouver and surrounded area , This is a money grab by our local government while the harbour is full of old ships burning bunker oil in Vancouver that is regulated by the federal Government
Vancouver Regional District Ticket Information Utilization Amending Bylaw No 1158, 2012 Reference: Greater Vancouver Regional District Non-Road Diesel Engine Emission Regulation Bylaw No, 1161, 2012 Column 1 Column 2 Column 3 Offence Section Fine 1. Discharge of air contaminant 6 $1000 2. Failure to comply with opacity and idling restrictions 10 $1000 3. Failure to comply with Tier 0 registration and labeling 11 $500 requirements 4. Failure to comply with Tier 1 registration and labeling 12 $500 requirements 5. Failure to comply with registration requirements 13 $500 6. Failure to provide information 14 $250 7. Failure to comply with Tier label requirements 18 $250 8. Failure to display registration number and tier label 19 $250 9. Failure to keep low-use engine records 21 $250 10. Failure to comply with low-use engine records 22 $250 requirements 11. Failure to comply with amended registration 29 $500 requirements 12. Operating a prohibited Tier 0 engine 32 $1000 13 Operating a prohibited Tier 1 engine 33 $1000 14. Emissions exceed an opacity of 20% 34 $1000 15. Idling for more than 5 consecutive minutes 35 $500 16. Failure to submit anti-idling procedure within 24 hours 37 $250
That's just stupid.
I agree that it is just a money grab, if you want to use your machine you need a 90 day permit that i bet will cost you.
Good to know if you have say an old diesel pump or generator in the back yard, you need a permet to operate that when you want.....
