changing hydraulic fluid bobcat 335
bingoo
when doing the 1000 hr hyd fluid change is it just the reservoir fluid that is changed or does the entire machine have to be drained . thks bingoo
If it's not contaminated, i can't see why you need to drain every drop, but you do want to get all you can.
Personally, i run my machine at idle and pump it out an aux fitting till it spits, shut down and re-fill. SOme don't like this idea as they feel the pumps run dry, but i feel there is always a film of oil in the pumps.
If you want to give it a good clean, do as listed above, add a jug of oil, run the machine around, lift/tilt/drive to get the new fluid around, then drain it again and re-fill. You don't get the lot, but it's a lot more than just draining the tank.
Remember, you have fluid in your cylinders, hoses, pumps and motors. It will not just drain out.
B
bingoo
thks tazza , good advise , this machine has never run any attachments etc , so there is less risk of dirt . Appreciate the help . bingoo
melli
That sounds scary....lol I mean one will get a lot more oil out your way, but I'd be wholly worried about messing up the pump. I just do the manual way, just more often than the manual says. I've moved away from Bobcat oil, as they are too far away, and shipping costs are insane. So, I get ISO 46 from the local hardware store when on sale. $60 a bucket. Wondering if I should use ISO 32......haven't noticed any issues with 46.....
From what i was aware, 46 was pretty close to bobcat hydrostatic fluid. Bobcat just have extra additives in theirs. Not sure on how close 32 is.
