The drive motor; leaks oil into chain compartment... On both sides... CASE; says ONLY fix, is to replace the motors, with new, "UPDATED," motors... To throw away the old ones. At approximately $1600.00 dollars each! (EACH) The motors models are, (177 0001 002) (VIS-40's) Charlynn EATON is the manufacturer... Sounds like a manufacturing flaw... IT should be recalled, anybody else have similar issues / problems; oil leaks, filters coming loose... Electrical problems? Etc... I have the CASE 70 XT. (POS) Reply when you can, any information would be greatly appreciated... Thanks
