Case 1845c injection pump
10klakes
Just bought a 1845c. Bought it knowing there were a few issues. When I first looked at it, it wasn't starting. Seller figured out it was out of diesel. Started after that a few times. Motor ran good when started. Now not starting. Today I tried to bleed the fuel system. Used the lifter pump and cracked the bleeders on the injection pump. There is diesel there. After the pump there is no flow. Crank the engine and no diesel after the injection pump. I'm just learning about diesels. What should I look for with the injection pump?
How do you shut it down? I'm wondering if there could be an issue with the fuel shut off solenoid. If it's off, you will get no fuel to the pump.
Hopefully it is that simple.
