Case 1845B Ignition/Electrical troubleshooting
Midwest Brian
Hi
I've got a case that sat for a couple years while I fixed hydraulic leaks. Now when I attempt to start it, I get nothing. Not a sound.
Battery is showing 13.5v
I pulled the selenoid and it tested good per online instructions
Pulled the ignition switch and that seems to show good continuity where it should
Fuse at the instrument panel area is good
Tried connecting 2 wires under seat to guess they were for a seat pressure switch (1). Don't know what (2) and (3) wires are for.
The battery connection where the wiring harness meets the ignition switch has nothing, nor do any of the other connections
Any help is appreciated.
Thanks,
Brian
Under Seat Wiring
Ignition Switch Harness
