Hello my wire came loose at pump? docBlocked filter? cracked pickup tube in the fuel tank? bad lift pump? bad fuel shut off solenoid?
Does it have a hand primer? you can open the line at the pump and use the primer to see if fuel is getting to the pump. If it is, it may be your fuel shut off solenoid.
