Case 1835c engine oil?
Petro1
What kind and viscosity of of engine oil should be used?
In a case 1835c with a tm20 continental 3 cylinder engine.
foton
I would think in hot climates straight 30 would be ok most anywhere else either 10/30 or 10/40 should be fine.
Petro1
Petro1
I'm in ohio. 1400 hours on the machine.
Synthetic, high mileage, or conventional oil?
foton
well I like to use conventional and just change it sooner than required, I do mine like at every 250 hrs. and being in ohio it does get cold enough there I would use multi-weight oil. most likely 10/30 if you have no oil burning issues. I will mention that 15/40 diesel oil will work too. It just has additives that gas engines does not need but will not hurt anything.
foton
I assumed that when you wrote it had a contentinal engine it was a gas burner, wrong! 15/40 diesel oil would be best for a engine .
