R Richard57 Active member Joined Jun 22, 2023 Messages 34 Jun 8, 2024 #21 It seems to come on a lot faster at low idle, maybe 10 minutes.
E Equipment_Tech Well-known member Joined Jun 16, 2023 Messages 152 Jun 8, 2024 #22 Your neutral sensor has nothing to do with charge pressure is pretty straight forward, either it works or it doesn't, they really don't go bad or need adjustments unless you cannot drive or intermittently locking breaks kinda deal
E Equipment_Tech Well-known member Joined Jun 16, 2023 Messages 152 Jun 8, 2024 #23 I would recommend starting with the most common basics. The machine should be equipped with a vented hydraulic cap. Your supposed to change this cap @ soo many hours based on your manual. I personally would try that first
R Richard57 Active member Joined Jun 22, 2023 Messages 34 Jun 8, 2024 #24 What about the adjustment on the solenoid for pump motors. Only because it seems to have started after I redid the wiring.
R Richard57 Active member Joined Jun 22, 2023 Messages 34 Jun 8, 2024 #25 One of the first things I did when I bought it last year was a new cap. It was filthy.
E Equipment_Tech Well-known member Joined Jun 16, 2023 Messages 152 Jun 8, 2024 #26 Is the code for high pressure or low pressure ?
R Richard57 Active member Joined Jun 22, 2023 Messages 34 Jun 8, 2024 #27 One of the things I was going to replace was the sender. Except Bobcat has them backordered until late July. 05-09 low charge pressure
R Richard57 Active member Joined Jun 22, 2023 Messages 34 Jun 8, 2024 #28 I know it's not called a solid but this is the part with open wiring. Can't find information on adjustment
E Equipment_Tech Well-known member Joined Jun 16, 2023 Messages 152 Jun 8, 2024 #29 I would mark your belt and pulley with a white paint marker, let it run for while and check your marks to see if the belt is slipping.
R Richard57 Active member Joined Jun 22, 2023 Messages 34 Jun 8, 2024 #30 Thanks, I'll give that a try tomorrow
E Equipment_Tech Well-known member Joined Jun 16, 2023 Messages 152 Jun 8, 2024 #31 The photo you sent me...... That is off the pump ??
E Equipment_Tech Well-known member Joined Jun 16, 2023 Messages 152 Jun 8, 2024 #33 In that case I would find out who makes the pump (id plate - example: Parker) and find a local dealer for the pump Bring that piece into them and let them test / inspect. It will cost a little but not like that amount unless they tell you its cracked or damaged
