Bobcat S570 Shutsdown
Baldbuilder
I have a 2014 S570 with 270 hrs on it. It started to shutdown randomly when operating it - no error codes. Now when I start it and hit the Green release button, it shuts down. I have to restart it 3-4 times before it stops shutting down when I hit the green release button. Any ideas?
To me it sounds like an electrical short.
Make sure to clean and tighten the battery terminals and all grounding points that you can find.
Clean and check all of the fuses and look for corrosion in the fuse housing.
Look for and rub throughs on the wire harnesses.
Check, clean and dry all of the wire harness connections using a contact cleaner.
Thank you. You think that is it?
