Bobcat s300 No start
Balls22
I have an s300 and it will not start. I have replaced the battery & starter and it still will not turn over. I have swapped relays and still the same issues. When attempting to start you hear the relay click and also hear the starter solenoid click.
Any tips would be great.
Thanks
Starter solenoid likely had burned contacts. You may be able to disassemble and coral them for a temporary fix
u have to try the starter first by touching the two wires on it and see if thery hot
if no turn starter no good if it turns than a wiring issue most like ground oe corrosion
