This post is for a good friend who is far away , I am trying to help him long distance , he is a very good Bobcat mechanic as he worked at the dealer for quite a few years and has had help from the dealer service dept several times on this problem , a grapple hose blew and two new hoses were put on the machine , 5 minutes later the grapple stood stuck on , after disconnecting the aux stem coils , cleaning and swopping the stems , and disconnecting the hand controll it still is engaged , blocking off the power Bobtack , they tried ll kinds of stuff Bobcat suggested a new controll valve as it must have a crack , changed the valve and problem still exist , I am telling him I think that a piece of rubber or wire from when the hose was cut which may have got into the system , probally the stem vavle , and stuck it or something else , he says the stem can be entergized off the machine and works fine , sees them move and click , swopped the postions and same results ------- langnappe info ------ whe you pull the aux trigger while the hydraulics are stuck engaged it stops the flow , but when you do this the stems are disconnected electrically at that time , so the electric signal from the trigger does go to some other function that has an effect on the machine but may not have anything to do with the problem , anyone seen this happen
