bobcat 763 HP-3 fault & Hydro oil temp light
teeroy
on start up HP-3 code is on all the time, also the hydro oil temp warning light is on even on start up when oil is cold. i tried jumping the 2 wires on each sensor but it comes up with code 4 wiring short. is there a way to test the temp and pressure switch befor i get new ones?
Hook a pressure gauge up to the spot the sensor is screwed into. I would suspect its just a bad sender, they do go bad. The computer does detect open and short circuits, whats why you can't just jump it.
The charge pressure suould be about 90-120 PSI so get a gauge that will read at least 150PSI
hey mate i hooked up a gauge no probs.. bought a new sensor but now im getting hp-3 hc-3 and think its hcf-1, all the wiring looks ok back to the black box under the cab. Is there somthing i can check before going back to the dealer? also with the lcd display when it shows the faults it shows 6o55 the zero is half size i think it means boss is this correct? or is this the hours..
It does mean BOSS
I'm not sure what the issue could be. Have you harassed your dealer to see if they have any ideas?
It does mean BOSS
Thanks. do you know if there is a way to turn the warnings off to see the hours on the machine as it does not show them when it has faults come up? the dealer where i am is not much help they thought sensor or wire problem.. could it be the computer? troy
I thought the hours would flash up first then the errors?
Its always possible its a computer issue, but as you did state when you shorted the sender out it showed as a short on the display. As its detecting this, its hard to believe its the computer....
thanks for all the replys got it all sorted turns out it was loose or bad connections to the BOSS, all works the hours now show. troy
