Bobcat 753H no lift partially bucket tilt
Thanks for quick response. I always thought Bulgarian was similar to Croatian but recently I had clients from Bulgaria and we did not really communicate well. This problem with my Bobcat happened at once. I think most oils come out under the oil gauge because it is tough and not sealed. Tomorrow I'll see where the vent hose is. I have to wash the machine to see where the problem is, and I think it has a problem also with the fuel because some fuel is on the place where is throtlle lever.
Check if the sensor itself is its plastic part dry? Over time, it burns and starts to flow through it. Instead of an accelerator lever, oil should be leak, not fuel. Check if it does not drip on top of the fuel return hoses. The vent vet starts from the valve cover and / has a raised part of the hood and a pipe passes behind the engine/.
I did not understand what a plastic sensor I should check?
Oil gauge has a plastic part вhere a wire is attached
Yes, the oil pressure gauge has a plastic part, a pin and a wire is attached to it. It usually runs through this part. The pressure gauge is right next to the fuel filler, are you talking about it?
